Sir,
Hi Aviral Kedia,
Can you please let us know which section in Quiz you are facing difficulty.
Sourav
Hi Sourav,
As i mentioned in the post, my contour , max and min results for grid temperature, displacement magnitude and von misses stresses are correct(as shown in pdf provided with exercise). Yet my results for questions asked in the particular quiz differs by a large amount from options provided. Why is this happening? I have attached my hm, h3d and pdf file for you to verify.
Kindly take a look and let me know if anything is wrong with it.
Aviral Kedia
Hi Avrial,
The results displayed in the pdf document is only for demonstration purpose.
Kindly make sure you download the correct model file provided for Quiz 8 and follow the steps mentioned in the pdf. This shall give you the correct answer.
You can download the model file from the pdf provided in the certification course (image attached for reference):
Thank You!
Hi Avrial, The results displayed in the pdf document is only for demonstration purpose. Kindly make sure you download the correct model file provided for Quiz 8 and follow the steps mentioned in the pdf. This shall give you the correct answer. You can download the model file from the pdf provided in the certification course (image attached for reference): Thank You!
I have rechecked everything. The model downloaded and the steps followed are as mentioned in pdf.
Kindly have a look through my hm file and h3d file.
Thanks & Regards,
Hi Aviral Kedia, Can you please let us know which section in Quiz you are facing difficulty. Regards, Sourav
Hi sourav,
My issue is yet not resolved. Kindly help.
Hi PrasannaK,
Hi Aviral,
I am working on it, will get back asap.
Hi Sourav, As i mentioned in the post, my contour , max and min results for grid temperature, displacement magnitude and von misses stresses are correct(as shown in pdf provided with exercise). Yet my results for questions asked in the particular quiz differs by a large amount from options provided. Why is this happening? I have attached my hm, h3d and pdf file for you to verify. Kindly take a look and let me know if anything is wrong with it. Regards, Aviral Kedia
I am also facing the same issue. Do you find the solution? the quiz values are completely different from the analysis solution result, but I got the same value as you mentioned in your PDF
Hi Aviral, I am working on it, will get back asap. Thank You!
We are deactivating this quiz (not required for the exam) until we finish reviewing it and updating it if necessary to ensure there are no issues with the results and answers with the new version etc.
Please continue on with the next quiz of the exam
