Hello everyone
I have a problem with the simulation when I get to the DOE step where optimization shows me this error.
To start the investigation, I'd suggest you to look at the Flux log files under the run folders to see why the simulation is failing (e.g. is it about unfeasible geometry, or mesh, or else). You can also click on the task_exe links you see in the Messages window.
Please look at the blog below to know more about the HyperStudy Flux connection. Could you please try the suggestions in the section Good practices?
HyperStudy Tips and Tricks: Know everything about the HyperStudy Flux connection
if you don't figure out the cause of the error, next step would be to share the study archive (*.hstx file) with us so that we can try to reproduce it.
Hope it helps.
Diana
