In ST 9.5 the rendered result of a image wraped around a sphere is very pixeled compared to the same render in ST 9.0.
Is there a setting you guys has changed?
Not that we are aware of. Can you send the file and the image you are using?
Thanks,
Hi Darren,
Sorry for being a little late in my reply….work!
I have made to files in 9.5 and 9.0 with a sphere with the same picture wrapped around (fairly large) and mad two rendered files. The difference is very clear.
Since I depend on this operation almost daily in my work, I would appreciate if you could pin point the problem - thanks!
This is very strange. I have tried every combination I can think of and I am unable to produce any visual difference between the two.
Can you email the .evo file and the image you are using to: chilton@solidthinking.com
