Hi you guys,
I have the latest build and El Capitan on my iMac.
I still have an issue when selecting an object or a line from the little popup menu that comes up when clicking on objects that are on top of each other. If I pick anything but the one in the top, the object I then select will jump a little step down equivalent to the position/line I pick from the popup menu...
Have you a fix for that and do you know of this issue?
