I have kept all my versions of Evolve. In my documents folder Evolve build up enormous amount of 'images' in a folder called 'Images'. When I look in the folder I can see EVERYTHING I have created in that version of Evolve piling up. In my preferences I have put Evolve to only save 5 renderings. And I can see that every file is accompanied with 5 folders. But I did not anticipate to se EVERYTHING I have created being kept. And I have no use for it. I can't even open any of the stuff down there.
There is a screenshot attached here where you hopefully can see what is cluttering my disk.
Is there a good reason for this? And if not, is there a setting that stops Evolve from piling stuff up on the disk?
