Hi all,
I'm new to SimSolid having previous experience of Ansys and Creo Simulate (ProE).
Regarding contact, I'm finding it frustrating that it doesn't seem possible to apply a contact to only part of a surface. For example bonding local to a bolt hole (if the bolt is not included in the model) and applying a separating contact to the remainder of the contacting face. Normally I would split the surface so that I could apply separate contacts but I don't see how to do this in SimSolid.
Does anyone know a workaround so that I can apply different contacts to different areas of a surface (or split the surface?).
Thanks in advance
