In the output window of the linearization tool "peak at entry" is listed what exactly is this? i assumed it was the the peak stress at the entry to the linearization path ie the stress at the node you peak first? but this doesn't correspond
using the tutorial example the peak stress is 145.5 MPA but the output window shows the "peak at entry" = 14.48?
