Hopefully this extract from the Help will help you.
Level-set is a kind of enhanced shape optimization that starts with a guess of holes in your model, and them starts re-shaping them to get the final topology.
The advantage is that usually it will give you a more discrete solution, meaning less mid-dense elements.
But on the con's, it has less manufacturing constraints available.
Hopefully this extract from the Help will help you. Level-set is a kind of enhanced shape optimization that starts with a guess of holes in your model, and them starts re-shaping them to get the final topology. The advantage is that usually it will give you a more discrete solution, meaning less mid-dense elements. But on the con's, it has less manufacturing constraints available.
These pictures and GIF show the idea.
