While solving an acoustic simulation of a motor assembly, why is there a negative ERP is being resulted?
ERP itself cannot be negative. If the power is less than or low enough to the threshold, then ERP in dB scale can be negative.
Is it possible to share the file?
I am trying to share the file in the drop box link.
It is around 65 MB.
But you drop box size limit is displayed as 48 MB only?
Hi Prasanna,
I have sent the FTP link to your e-mail.
Pl download the file from there.
Karthik
Hi Karth,
I did not receive the email. Will you please sent it over again?
Pl confirm whether you had received this time.
I had sent to prasanna.kurhatkar@altair.com.
Pl check the junk folder too.
Sorry for the late reply. We unable to open the file shared by you, as the file uploaded is expired .Could you give a final try by uploading the file in drop box available in my signature
Rahul,
I had uploaded the file.
Is that now or last week?I dont find anything in my outlook.
Note: If you are a commercial customer then you could also reach local technical support team.Please check the details below:
https://altairhyperworks.com/ClientCenterHWSupportProduct.aspx
