Hi Guys,
I am having a problem with unrealistic displacements. The first image below shows the wheel modelled with pretension in the spokes (different tensions on each side) This is what I expect to see.... The spokes are under tension and the rim mainly under compression with areas of peak stress around the parts where the spokes attatch.
However when an additional force is added to the rim, I get the response in image 2. The forces added at the bottom, they are around 0.75kN in x,y,z. The problem is that the spokes which should increase in tension just stretch without increasing in stress?? (the stress is the same as the first image) . The main error here is the displacement of the spokes even though they are fully constrained.
Iteration Subcase Variable Grid/Elem ID Value
0 1 MaxDisp 209 -391.773
0 1 MaxStress 1474088 8083.37
Does anybody know how i can stop this displacement from occurring?
I'm pretty sure its not a constraint issue this time!
Thanks,
Anthony
