error % radioss
I launch a crash calculation and from the start the augment error until 99% !! any idea please ?
Hi Oggy,
Please check for initial penetration in your model.
When you have initial penetrations, If you are using Igap=0 then reduce the Gap_min value to clear the penetrations. If you don’t wish to do this, use INACTI=6.
0 -
i'm using hypercrash not hypermesh for pre-processing
0 -
In HyperCrash, Goto Quality>> check intersections of tree selection for intersections and penetration (shell elements) check.
0 -
hi,
I have this problem:
CYCLE TIME TIME-STEP ELEMENT ERROR I-ENERGY K-ENERGY T K-ENERGY R EXT-WORK MAS.ERR0 0.000 0.6438E-04 SPRIN 614559 0.0% 0.000 0.000 0.000 0.000 0.000RESTART FILES: Calcul3_0001_[0001-0001].rst WRITTEN-------------
0 -
I have also encountered the same problem and i have checked my initial penetrations where i have kept IACTI=6 already.
0 -
By using Inacti=6 the nodes will be slightly depenetrated but if the penetration depth is more this option will not be effective. The user has to depenetrate those.
