There is any possibility to convert beam element to rigid body automatically ?
Hi Oggy,
I dont see there is a direct conversion for this. You have to do this manually.
Thanks a lot
Hi prakash,
Can you please tell me how to convert the elements to rigid wall & Do we have to assign any property for that
Regards
Ajay
Hi Ajay,
You cannot convert existing elements in to a rigid wall. But if needed you can make the existing elements rigid by creating rigid on those elements.
For creating a rigid wall, select a base node and select the type and choose the normal vector. For rigid walls there is no need to assign any material or property.
Thanks john for giving reply
I want to move the Rigid wall that hit the part.It is one type of impact analysis. So how can set up the simulation And can define load Vs Time curve to rigid wall is it possible.
It is possible to provide velocity to the rigid wall but we cannot provide it as a function.
In that case create a surface, make it rigid and you can provide an imposed displacement load with displacement vs time function.
Thanks john
So how can we make it rigid As element to rigid how it possible ? Can you please tell me.
HI Ajay,
From 1D panel>Rigids, select the elements and create rigid.
Please go through https://altairuniversity.com/wp-content/uploads/2016/11/Crash_Box_1.pdf tutorial where all these steps are shown.
Thanks john,
Can you please check once i am trying to move the rigid wall but it is not working can you please check once for me please.
Please try with the attached files.
The surface was not rigid. I made it rigid and applied the loads.The interface was also properly defined.
Great thanks John . See you later
Hi john,
I am doing impact analysis with rigid body moving with certain velocity. But the H3d is not writing with this file i attached the file can you please check once.
