Hi !!
I have this errors in hyperCrash any help please
Oggy,
Looks like the nodes of the springs are not connected.
Please update or re-create spring and try again.
Thanks Mr,for the first Error in Rbody element have you any suggestion ?
I am not really sure what the error was referring to.
can you share the model file?
can you see this picture to understand the problem
Hi Oggy,
I can't make out what the error is about from the picture.
please share the model file.
Please Note: If you are a commercial customer, you can contact your local support @ http://www.altairhyp...ortProduct.aspx
