I imported a dummy and when I went to check the model with HyperCrash I found the errors below. Any suggestions please
Hi oggy,
Looks like there is a modelling issue with rigid elements.
check if the master of one rigid element is shared with any other elements?
You can try fix this using Correction on the top of the model checker browser.
if the master of one rigid element is shared with other elements, what can i do to resolve this problem ?
One trick is to detach elements from the node which are sharing the rigid master node.
use 2D>> detach
