Help PLease:
When i want to solve a modal Analysis optistruct shows me the following message
Hi Oggy,
It is not clear to what the error is pointing to from your post. could you please share the entire out file.
Hello Prakash,
i have the same problem.
Is it cause i reloaded the FEM file to do the optimazation?
Could you please help me to solve this problem?
Best regards
ann123
Hi Ann123,
Can you share the entire .out file?
No laminate/property is refered for freesize setup (DSIZE card). Please check, update and run the analysis.
Thank you for you'r help ! But unfortunately now I have the next error.. *** ERROR # 6010 *** DCOMP 2 defines constraints for STACK 3 which cannot be satisfied. These constraints are initially violated but they do not involve any designable plies.
hi Ann123,
Since I dont know which laminate you have referred and to which DSIZE, I can't really suggest a solution.
Please share the modified deck to the dropbox link in my signature below
Balance constraint is used when there are +45 and -45 plies are available. In your laminate there are only +45 plies.
Also, remove membersize constraint on DCOMP
Hi Prakash, I tried to solve the problem that way but I think there are some more faults.. If I delete the balance in the free size than nothing is happenig and if I delete the balance in the composite size than my plys are empty. It is to despair..;)
Ann123,
Even with Balance the size DVPRELs are empty. Looks like plies did not referred in the size parameters. Can you cross check this?
