Do anyone have H-arm geometry for doing MBD analysis. If anyone have pls snd the step file to this mail id - antonypaulkj21@gmail.com
Hi @Antony Paul,
In case you still need it, I created a H-Arm model in Inspire that is parameterized using Design Variables. Based on your specific needs, you can update the H-Arm variables and then export the model as a STEP, STL, or parasolid as needed.
Please find the model attached:
Hope this helps!
Adam Reid
