How do I fix my bottom panel?
There's been a problem with my bottom panel in Hypermesh. It is completely gone, like in the picture shared. I'm not sure how to fix. Should I uninstall and install again? Also, I heard about deleting settings files, but it's not currently working, saying I don't have these files. Please let me know what the best approach is.
Thank you,
Justine A.
At the top of the screen there is the View tab. Do you see Panels as enabled here? It should have a checkmark.
With regards to the settings files, are they being written to a path your account has permissions in? You can check this by right clicking on the HyperMesh shortcut, opening properties, and ensuring the "Start in:" path points to a place you have access to. Normally this is the user's Documents folder.
1
