'*** ERROR # 7590 ***
LATPRM,CLEAN,QUAD and HS is only allowed for lattice size optimization.'
I do a DoE of the Latticeoptimisation. Every Datapoint is a full Lattice-Optimisation(Phase 1 & II ).
Parameter: All Lattice Parameter from DTPL(+Lattice) and LATPRM
Every time LATPRM, CLEAN is YES I get the Error 7590.
When I use Default or 'NO', there is no Problem.
According to the Help 2019 'YES' is Default!?
Attached:
- minimal example (Cube) - see Line 52 in *.fem
- Result_of_DoE_for_Debug.xlsx
Thank you for your efforts in advance
