I am trying to run the indoor_propagation.cpp example on Visual Studio. I have used cmake for creating the VS project but when I try to just run the example, I get the following error:
Is there any step I am skipping?
Thanks in advance.
often the files on the C drive are protected, so you should either install the WinProp API package on the D drive or run Visual Studio as administrator.
Yes, I was aware of that and I tried as administrator. However the problem persists.
I got the solution. The problem was it must be specified 'set up as startup project' in the actual project. By default is placed on 'ALL_BUILD' which is incorrect.
Now this is the problem that I have:
Problem solved. In case someone is interested:
When I installed the Feko + Winprop software I pointed the environment variable to the license server. However, when using the API you need to configure it as a Windows enviroment variable to make it work.
