When I change the orientation of a section or apply a load, the model doesn't save these changes. Why could this be happening?
What Altair product are you using?
Sorry Elizabeth, I forgot to specify. I'm using S-Frame 2023 in Windows OS. I saved the file and opened it again, but there were no further loadings, and the section orientations were not applied.
Moved your question to the S-Frame forum for better visibility.
Hello, Kleber,
Thank you for reaching out. Without having more information, it's difficult to pinpoint the exact cause. I would suggest creating a support ticket (Create a Ticket) so we can investigate further.
Alejandro Lopez
Altair Support
Thanks Alejandro. I will do it.
