Is it possible to predict blade failure in a mixer grinder using acusolve or nanofluidx at 1700 RPM when water is churned in a conical jar which is around 1 liter water and 0.5 liter air closed at top.
Thank you.
AcuSolve of NanoFluidX are just CFD solvers and what you probably need is a fatigue solver for your use case.
You could get pressure on blades with AcuSolve and map these pressure values to OptiStruct and use HyperLife.
https://www.altair.com/hyperlife/
