SEQUENTIAL ANALAYSIS
i have to carry out analysis on structure on which load is to be applied in sequence,
i am creating a state file for strain data and exported the deformed shape from post processing
but it doesn't export contacts, material and properties,
to carry out 5 sequence 5 simulations are required
what can be other way to carry out simulation in one go?
i've tried to use tstart and tstop in loadcard definition but its not working
You can do sequential analysis in RADIOSS by defining a curve for this loading. For all the load cases define the curve and you can run the same in one go.
Refer tutorial RD-3599 (Gasket with HyperMesh) for better understanding on defining the curve.
0 -
@George P Johnson thanks
0 -
Iam also performing Drop test simulation in radioss. actually i need to perform sequential drop test simulation. can you explain me the procedure for setup or option for sequential drop?
