error in putting up restart file
i am trying to run a job via a restart file generated when i solved the job using (-nt 15 and -np 15) 225 processes.
i am inputting same command line to use 0002.rad files but the job isn't running. there are 15 files present for restart - 0001_0001.rst to 0001_0015.rst
but i am unable to run the job .
it is giving me following error
i am attaching 0001.out and 0002.out files
Hi Harshit,
We are working on your query and will update you very soon.
0 -
Hi Harshit,
The error output deals with « END OF FILE DURING READING », and this can be generally due to some restart files corrupted between Starter step and Engine step.
Would you try to run again RADIOSS Starter and double check there is no error like no more disk space for instance, that the Starter completes without any errors.
Then, rerun the Engine and please update.
0 -
Sir what are the other reasons for this error.. I've encountered the same
0 -
Hi Ramakiran,
The possible reasons for this error are listed above. Please check the same and try running the analysis.
