I am trying to run a simulation on Linux server , the animation files are generating very slow than expected and models begin with an error of 5.4% an d reach 99.9% also hyperview is unable to read that file it is unable to complete reading process.
Cam you share the deck file ( _0000.rad ) file?
If not, please share the.out files ( starter and engine out files)
i' m attching .out files
please upload the model file (_0000.rad) . Need to look on the load provided.
Looks like a convergence issue. Can you check if there is any problem with loads, and also with contacts?
