i am trying to simulate shear failure in bolt in which head of bolt tears off due to shear load. I've used type 13 spring along with a local co-ordinate system and pre-tension curve . What is the best way to capture shear load failure. and what is the best way to apply pretension type 32 or type 13 spring. Should washers be modeled as rigid.?
