TCL scripts for importing nodes and elements from csv files
User: "JZ_21971"
Altair Community Member
Updated by JZ_21971
Hi guys! I am a new Hyperworks user and have some basic questions. Now I have 3 csv files and I want to import/read them and build a FEM model based on them. Here is an example.
node.csv stores the node coordinates.
0,0,0
1,0,0
2,0,0
3,0,0
0,1,0
1,1,0
2,1,0
0,2,0
1,2,0
0,3,0
quad.csv stores the node numbers for quadrilateral elements.
1,2,6,5
2,3,7,6
8,5,6,9
tri.csv stores the node numbers for triangular elements.
3,4,7
10,8,9
9,6,7
The attached image shows the model built in Ansys including 3 quad elements and 3 tri elements. I believe it can be done by simple TCL scripts in Hyperworks but I totally got lost when I read the coding tutorial. Can anyone help me with this? Thanks in advance.
1 - 1 of 11
    User: "QuyNguyenDai"
    Accepted Answer
    Updated by QuyNguyenDai
    Some ideas to make a script:
    • Read node.csv & create nodes with the command "*createnode"
    • Read quad.csv & tri.csv and create elements with the command "*createelement"
    Here's my "Proof of concept": put 3 CSV files + script in the same directory & run macro. See attached zip file.
