Hello to all, i would like to know how to isolate only failed elements. it is sometimes really difficult to correct an element, which is in the inside of the model. Thanks,
Umehr
There is a "save failed" option in "Element Quality". You can then retrieve this selection and isolate those elements. Sometimes if they are spread out it can still be hard to find so turning on the ids helps and then possibly repeating this as you correct some elements.
You can also set the view by element quality and click on specific criteria to see the ones that are failing.
