I have a model with a dummy positioned on a seat. I need the belt to be snug to the dummy and also lock in the event of a front impact. To do so I connected the belt to the seat frame with a spring2 element to which I associated the property /PROP/TYPE32 (SPR_PRE). Inside the property Ilock=1 was set, as well the slide length D1, as sensor a nodal distance sensor was used between the two nodes of the spring2 element. The slide length D1 is smaller than the actual distance the spring shortens during the first part of the analysis (the first fase while, due to gravity, the dummy lowers itself on the seat, deforming it) so I would expect the spring to lock when it shortens by D1 and never extend afterward. Sadly, during the second part of the analysis (a front impact) that doesn't happen and the spring2 elongates.
Does any of you know why is that? Am I using the wrong property? Every help is much appreciated
