Hi guys,
Hope all are well. If I want to simulate the deformation of geometry, like bending, i.e. the blade used to mix the strong particles at high speeds, which software should I use to couple with EDEM. Thank you very much.
Best wishes
Sunny
Hi Sunny,
If the geometry deformations are not too large EDEM coupled with MotionSolve (Which is a Multi Body Dynamics Solver) is a good option to simulate.
More examples of EDEM+ MotionSolve can be found in the Motion View/Motion Solve help.
Thanks,
Prasad A
Hi Sunny, If the geometry deformations are not too large EDEM coupled with MotionSolve (Which is a Multi Body Dynamics Solver) is a good option to simulate. More examples of EDEM+ MotionSolve can be found in the Motion View/Motion Solve help. Thanks, Prasad A
To add to Prasad's answer - if MotionSolve is appropriate for linear elastic deformations up to 10% strain.
Best regards,
Stefan
