when I start the Altair analytics workbench, I receive following error:
The Altair session failed to initialise : Location of SASHELP library is empty
I checked the Config file: wps.cfg and there I have defined the path to the SASHELP and it's not empty.
I'm using Altair SLC (previous WPS) version 4.04
Thank you
Hello all,
I have found the RCA for this issue. Simply the wps.conf file had wrong permissions, so the Altair analytics workbench couldn't read it properly.
So hopefully this will help someone
Hello all,
