i cannot see the fixed points( as spheres) and i dont know why.
can someone help me.
https://imgur.com/mkKwPiz
Please check by deleting setting files.
https://community.altair.com/community?id=community_question&sys_id=044688761b2bd0908017dc61ec4bcb69
thats not working, i have tried to delete all the files then i even change the working directory, the funny thing is when i 2d automesh i see the nodes, but when i try to create temporary nodes, i just cant see them
Which version of HyperMesh you are using?(Student Edition or Full Version/2017 0r 2019)
Share screenshot of Help: Updates and System and Information
Operating System?
I tested this in EDU 2019 version and it works as expected.
In the 2019 version we made changes in the graphic engine. Please test briefly if the environment variable HW_USE_OPENCL changes the behavior. Please do the following steps: 1. Stop all instances of HyperWorks 2. Set the environment variable to HW_USE_OPENCL=0 3. Start HyperWorks and check if the behavior has changed when clicking Grids.
or
Try updating graphic driver.
excuse me for the ignorance, but where do i find this variable? i dont have it, and where do i change it?
i updated my graphics card and nothing changed.
UPDATE :
I dont believe it, but the problem got fixed, thanks!!!!!!
after the new Environment variable.
Thanks for the update.
excuse me for the ignorance, but where do i find this variable? i dont have it, and where do i change it? i updated my graphics card and nothing changed. <?xml version="1.0" encoding="UTF-8"?> UPDATE : I dont believe it, but the problem got fixed, thanks!!!!!! after the new Environment variable.
what to do in this? i dont see 'HW_USE_OPENCL=0' option in this. please help
It's not working..... please suggest something else.
this procedure is not working....is there any other solutions
Did you try with the environment variable suggested above?
Teste isso na versão EDU 2019 e funciona conforme esperado. Na versão 2019, altere o mecanismo gráfico. Teste rapidamente se a variável de ambiente HW_USE_OPENCL altera o comportamento. Executeas seguintes etapas: 1. Pare todas as instâncias do HyperWorks 2. Defina uma variável de ambiente como HW_USE_OPENCL = 03. Registre o HyperWorks e verifique se o comportamento foi alterado ao clicar em Grids. ou Tente atualizar o driver gráfico.
ou
Como define essa variável?
How do I access and change 'Set the environment variable to HW_USE_OPENCL=0' ?
I have the same Problem, but could not solve it by Setting this environment variable. Here is my System Information:
System Information: ------------------------------------------------------------ Machine: amd64 OS: windows Windows NT 6.2 User: Julian
Hardware: ----------- Processor: Intel(R) Core(TM) i7-4558U CPU @ 2.80GHz (4 CPUs), ~2.8GHz System Manufacturer: Apple Inc. System Model: MacBookPro11,1 Total Physical Memory: 8192MB RAM
Operating System: ------------------- Machine name: DESKTOP-QH8R045 Operating System: Windows 10 Pro 64-bit (10.0, Build 18362) (18362.19h1_release.190318-1202)
Graphics/Display/OpenGL: --------------------------- Name: Intel(R) Iris(TM) Graphics 5100 VideoProcessor: Intel(R) Iris(TM) Graphics Family AdapterRAM: 1 GB DriverVersion: 20.19.15.4835 DriverDate: 20171016000000.000000-000 CurrentBitsPerPixel: 32 VideoModeDescription: 2560 x 1600 x 4294967296 Farben
Can you tell me how to make the nodes visible in hypermesh. Though I created nodes I am not able to see it.
What exactly should we change as environment variable .It asks for browse file .Is it the name of the variable or the path.what should be the path.
I have updated the environment variables. Still It is not working could any one help me on this.
I changed the graphic processor to run the software. It worked out for me.
Same problem, can't see any nodes using student edition
Creating a new system variable 'HW_USE_OPENCL' and setting its value to '0' has solved the issue for me.
MacBook Pro with Intel Iris Pro 550 Graphics running latest Windows 10.
I tested this in EDU 2019 version and it works as expected. In the 2019 version we made changes in the graphic engine. Please test briefly if the environment variable HW_USE_OPENCL changes the behavior. Please do the following steps: 1. Stop all instances of HyperWorks 2. Set the environment variable to HW_USE_OPENCL=0 3. Start HyperWorks and check if the behavior has changed when clicking Grids. or Try updating graphic driver.
