I have a model where a component has to be modelled being in different positions. This part in the model has to rotate say 10degrees intervals. I want to create an include file so that I can enter the angle in that include file and run it again without making changes to the rest of the input deck.
I have done something like this in radioss and ls-dyna a long time ago using transformation card i believe.
How can i do this in optistruct or nastran?
I can create an element set of the part that needs to rotate and a node to rotate about in the Y-axis. what card do i use?
