Hello all,
I am doing a 4th year final project and faced a problem on what we should add to change the parameter. We have a pressure relief valve here to simulate our loop flush. And we want to match up the flow rate and pressure data for the loop flush to the data sheet graph, which is the graph with pink. Is there any way to not change the flow rate and lower the pressure in the model to match up the data sheet graph? Or any other components we can add in to match up the graph? Pictures and model are all posted here.
