Hello everyone ,
i need aware about that Optistruct moadl analysis (force loading) what type card image use it and have 5 different constraints and same load , how can i manage that type condition
Refer Optistruct user guide & tutorial for Modal Analysis.Load collector with EIGRL card is needed to carryout modal analysis & same need to reference under loadstep Method Structure.By creating different load collector you can manage boundary condition.
Hi Yukesh,
What do you mean by 5 different constraints and same load?
Is it like 5 different simulations? If this the case, you can create 5 different loadsteps.
If you want to add different SPCs you can use SPCADD and use the same as SPC reference in loadstep
