Can we assign contact in gravity static analysis. Because i am not getting realistic result with contact.
Thanks
Narasimhamurthy
Hi NarasimhaMurthy,
You can have gravity load with contacts in a NLSTAT subcase.
The Gravity will be applied to the entire structure.
Please note: If you are a commercial customer, you can contact your local support @ http://www.altairhyp...ortProduct.aspx
