Exercise_6.1_Crush_Tube_Interface_Parameters
narasimhamurthy
Altair Community Member
Hi Narasimhamurthy,
Please ensure that you have provide the proper value for initial velocity.
Can you share the model file?
0 -
Hi
velocity is -13.3 m/sec in Z-direction.
please find attached starter file.
0 -
Hi Narasimhamurthy,
I just recreated the Type 2 interface and updated the load. Please try with the model attached.
0 -
Thank you very much.
In initial velocity load collector, I have assigned GROUND-COMP SET in ground id, here set was created by COMPONENTS entity.
now changed to GROUND NODE set and set created by NODES entity. it is working.
