I am using MAT9ORTH card for material property. and for physical property PSOLID has used.
getting error as shown below picture.
Please give suggestions, how to eliminate this error.
Thanks and Regards,
Narasimhamurthy
Is this a optimization run? If possible share .out file of the run ?
please find attached output file.
there is no optimization. Just analysis .
Could you please check the comment 3 of MAT9ORT which might be causing a problem.
