AcuRun fatals out with the last few lines of the .log file:
acuView-impi: *** ASSERTION in Function <vfmLsquare> File <vfm.c> Line <1864>
acuView-impi: *** Exceeds max smoothing passes
acuView-impi: No. negative viewfactors = 60572
acuView-impi: Redo least-squares, pass = 11
Abort(1) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
acuRun: *** ERROR: error occurred executing acuView
acuRun: Wed Oct 19 08:07:44 2022
Higher in the log file I get the Warning message:
acuView-impi: *** WARNING: A potential hole in the enclosure; check the model
However, the triangles enclosing the fluid volume form a closed volume with no edges and consistently oriented inwards.
Does anyone have any idea what else could cause the error?
Thank you.
