hs-1535
Hi everyone,
I am trying to go through v14 tutorial HS-1535.
After opening Hyperstudy from within Hypermesh-Desktop and Launch, I encounter the message:
Unable to find E:/hs1535/approaches/nom_1/run_0001/m_1/inflow_pressure.osi
Error writing E:/hs1535/pipe.xml
The working directory is E:/hs1535 where I copied pipe.hm and run_acusolve.bat
The Solver Exec dir is in the HyperStudy Job Launcher points to C:\Altair\14.0\acusolve\win64\bin
I have tried pointing it to an edited run_acusolve.bat without succes.
I vaguely remember some versions ago there was a similar tutorial 3000-something which worked ok so I am clearly missing something.
Any help much appreciated.
Cristian Cursaru
.Osi File is generated after a run of AcuSolve (and AcuTrans). I am not sure if the nominal run was done to get this .osi file.
Is it possible for you to upload the entire run folder as ZIP or maybe few screenshots?
0 -
Thank you for the prompt reply.
The run folder is attached.
The file pipe.hm is the one before lunching HyperStudy (with the shape and DV defined) not the original tutorial file.
