Hello all,
With the new multiphase capability in AcuSolve, is it possible to have more than two fields?
I'm a trying to simulate the mixing of water and a non-newtonian fluid, squeezed into air, out of two cylinders.
If both chambers contain the same fluid, then a Multifield fluid-air model model worked fine but visualisation of the mixing of water with the other fluid is also required.
Thank you
