Hi all, I deployed PBS pro(free demo) cluster with 2 host.
- node138: altair license manager, server host, execution host
- node139: execution host
And installed Singularity on both node and I have confirmed it worked.
[pbsdata@node139 ~]$ singularity exec /home/pbsdata/singularity_img/lolcow.sif cowsay moo
_____
< moo >
\ ^__^
\ (oo)\_______
(__)\ )\/\
||----w |
My goal is that job script command run on the singularity container without singularity command like "singularity exec ***.sif command" in order to entrust container management to PBS.
In the Administrator's Guide, there is Singularity sample command;
qsub -v CONTAINER_IMAGE=pbsuser/test-image
Then I prepared Singularity image file and job script.
#!/bin/sh
#PBS -N lolcowJob
#PBS -l select=1:ncpus=1:host=node139:container_engine=singularity,walltime=00:01:00
#PBS -o output.txt
#PBS -e error.txt
#PBS -v CONTAINER_IMAGE="/home/pbsdata/singularity_img/lolcow.sif"
cowsay moo
But it seems that the container does not start and the command in the container not found.
/var/spool/pbs/mom_priv/jobs/554.node138.SC: line 1: cowsay: command not found
Could you tell me where is my misunderstanding?
Thank you.
