I'm a new PhD student trying to run Biomechanical models of Seating simulations left by a previous student. I would like to perform a biomechanical Static simulation of Occupant-Aircraft seat interactions in Hypermesh Radioss. The termination time is 450ms. When I run the starter and engine files (using the '-both' option) in Radioss, 48 animation files get created and after that the analysis is stuck at 238ms (see picture below) and Radioss is stuck in a 'Restart Files' loop.
Can someone please guide me on why I'm facing this problem and how to resolve the issue?
Also, can you please tell me if this is run using explicit or implicit method? I don't know how to identify if this is a static simulation or not? Can you please explain how to define the engine parameters for running a static simulation, please?
Here's the Engine parameters already defined by the previous student in this model:
Run time- 450ms
TFILE - Time_Frequency = 0.0 (Type 4: Binary IEEE 32-bit (Default value))
DT/CRICK/CST - Tscale = 1.0 and Tmin = 0.0
DYREL - T_Period = 30.0 and Beta_Relx_Factor = 1.0
OUTP/DT - Tfreq = 5.0
RFILE - N_cycle = 40000
ANIM/DT - Tfreq = 5.
ANIM/BRICK/TENS/STRAIN and ANIM/BRICK/TENS/STRESS are defined with 'IJK' selected.
I'm new to Hypermesh and Radioss , and any useful suggestions and assistance would be really appreciated!
Looking forward to hearing your suggestions!
Thank you very much!
Best regards,
Goutham.
