Hello!
I was wondering if there was a way to export out the statistics for each column that is populating in the preview data before you load the selected table.
The reason is that we have used Monarch to clean up large data files and export out to csv files. We then upload those into another program and we have found a bug in that program that does not bring in all the data but we lack the reconciliation power to fully vet it out. We are thinking our only option would be to open the original file in data prep studio and just manually review the stats in the preview window and compare them to what gets loaded in the other program that is needed to perform the work we do.
I have attached an example of one of the columns that we would like to export. In that example there are 297 unique instances that we want to ensure that the correct number of each were loaded into our other program.
Thanks in advance for any advice given! ~Todd
