How to run Optistruct jobs on Ubuntu terminal
alpha_21885
alpha_21885 Altair Community Member
edited March 2021 in Community Q&A
Hello Optistruct experts,
I want to use Linux Ubuntu O.S to calculate Optistruct jobs. Could you help instruct me how to submit the jobs from command line.
I browsered to Altair/HWsolvers/Script folder then typed the below command: sudo ./optistruct.bat 'test.fem' -nt 4
But it does not work.
Thank you very much for any advice and recommendation.
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited November 2017
    Firstly, you have to know that Ubuntu Linux is NOT supported by Altair Hyperworks.
    So try with CentOS Linux, a free distro of RHEL which works well with Hyperworks.
  • alpha_21885
    Hello Mr. Dai,
    Thank you very much for your information.
    In fact, I can run Hypermesh on Ubuntu then I think Optistruct will work well on Ubuntu.
    May I know the command line you use to submit the jobs on CentOS as well?
    I search on this forum but there are only few topics on linux O.S.
  • Altair Forum User
    Altair Forum User
    Hi @alpha
    Try this instead:
     <install_dir>/altair/scripts/optistruct 'filename' -option argument
  • QuyNguyenDai
    Hello Mr. Dai,
    Which version of Hypermesh you can run on Ubuntu?
    All scripts are in <INSTALL_DIR>/altair/scripts/
  • alpha_21885
    Thank you Mr. Dai.
    I know where script is placed. I browsered to script folder then try few linux command but it does not work. (Please read my question in the beginning carefully).
    I just do not know how to run *.bat file in Linux.
    It sounds both you and Prakash are using windows to answer linux questions :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • QuyNguyenDai
    Hey, how you can found '*.bat' files within Linux installation?!?!
    .BAT file is Windows's script format.
    No .bat files within my Hyperworks installation under Linux (see screenshot)
  • Altair Forum User
    Altair Forum User
    All,
    .bat is Windows file and can't be used on Linux. Use OptiStruct solver command
     <install_dir>/altair/scripts/optistruct 'filename' -option argument for linux
  • alpha_21885
    Good morning Mr. Dai & Prakash
    Based on your advice and comments, I am able to run few Optistruct jobs on my Ubuntu machine successfully. Now I can remote to my Linux machine to run some jobs as well.
    Thank you so much for your help!!!
  • QuyNguyenDai
    So you run Optistruct solver only on Ubuntu?
    Could you run also Hypermesh/Hyperview GUI correctly on Ubuntu?
  • Hoan_21498
    Hoan_21498 Altair Community Member
    edited March 2021
    I have just installed HW 2021 in Ubuntu 20. It works normally.
