When I import PARASOLID file to Inspire form. All surfaces become a single part.
How to create new part and reorganize in Inspire?
I found the workaround solutions for this. I use HWx (Displayed export) each components (Die, Blank, Punch, Binder)!
HWx is quite easy to do this
Use the Partition tool in geometry ribbon and select the surfaces that you want it to be moved to a new component. Accept the selection and enter 0 for offset value. This will move these surfaces to a new part.
Not sure about your context. If you want to create tools using these surfaces You can select them while configuring the tools. There we have partition option to do the same as well with less mouse clicks. Refer tutorial Single Action Draw Simulation with Manual Setup for the steps.
