I want to morphing hexa/penta seat cushion with Radioss?
I often use P14_SOLID for Hexa and Tetra elements but unable to run with Penta elements?
Could you advise for this?
Thank you.
The pentahedron element is currently only supported as a thick shell Isolid =15 element and used with /PROP/TYPE20 (TSHELL).
Thank you George very much for your fast response.
I have never used thick shell solid. Could you explain the difference b/w normal solid shape element and thick shell solid for application purpose?
In the same file with property P14_SOLID please update the element type (2D>>elem types) of penta elements (keep the element type to PENTA6DG) and see whether it works.
Hi George,
Appreciate your prompt support again.
I update Penta elements to PENTA6DG and Radioss ran pretty well.
Thanks again!
