I used to work with the old style, tabs in the bottom of the window. Now I want to work with the new GUI, but do not fid everything... When I using the commands with the search function I come always to the old style. That is not really helpful!
1. Is there a matrix which shows me where all commands have the place in the new style?
2. I wanted to create between two tubes (with gap in between) a new solid, which connects everything to have a mesh with coincident nodes. But I did not find a way in the new style. At the end I have to create two surfaces and create a solid with surrounding surfaces (old style). The selection was a disaster (mask, find attached etc.) How would be the new process...?
Kind Regards
Carsten Manneck
