I try to import mesh (*.fem or *.nas) to Inspire form to run One Step Analysis but I am unable to run simulation
May I know your advice for this?
Hi Alpha,
You cannot import .fem, you need to start from .iform.
Thanks
Sourav
How to take the springback results in Inspireform ? by which principle/model does springback is being calculated????
springback can be performed from scratch, starting from your blank, using multi-stage setup.
Or if you already have a model run, you can import the .sta file with mesh and residual strains and perform further operations. There are a few tutorials for that on help.
