Unable to show/hide or rotate model when adding surface contact?
When I add 'element' for surface contact in entities editor, I cannot rotate/pan or show/hide components to easily select.
Could you have any better method to do this?
Many thanks
Thanks Prakash,
After reset (Delete some files in working folder) HM, I can rotate model normally.
But I still cannot show/hide comps when stay in 'add solid faces'.
However, I already created a script to do this very quickly (4 clicks to create contact group+select master/slaver+contact type). Default HM may requires 20 mouse clicks.
0 -
Thank you for the update.
If the script is sharable, I request you to share which can be useful for other users /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
