Hello Inspire Form Experts,
May I know how to display the distance (dimension) in X, Y, Z direction?
Inspire Form only display in total length?
Now I have to calculate the Z distance by click on each points (get X, Y, Z)
I found the solution for this.
Just double click on the Text dimension, it will expand.
Inspire 2019.2 cannot select points via transparent parts. Inspire 2019.3 can select the points under transparent part.
